HobbiesHobby ForumWikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Trains & Railroads > Model Railroading > N / Z Scale Model Trains
WON'T YOU JOIN US?
You are not a registered member and
are viewing this site as a guest.
Registration is simple and FREE.
Join this CrowdGather community today.
Registration offers the following perks:
» Less advertising throughout
» Post and participate in discussions
» Network with other forum members
» Free private messaging
join
Reply
Thread Tools Display Modes
Old 06-23-2007, 04:21 PM   #1
PennCentralFan
Uploads: 0
Default sectional track popped out of rail joiner how to fix?
I am using atlas sectional track code 80. In my layout, one side of the track slipped out of the rail joiner. Of the four rails of track that come together by railjoingers one of the three is out of the rail joiner, but only one side. So out of a combination of four rails joined by two rail joiners one side of the connect points is out of the railjoiner.
As you can imagine there is a bump where the track is raised. I elmer glued the track (non-diluted) to a cork road bed. I noticed this while I was painting rail.
How can I fix this? When the paint dries I'm going to run a loco and a box car or two to see how it has impacted the track.
I was thinking of spraying or applying water to loosen the glue and pull up a few sections of track to fix the problem.
What have you guys done?
PennCentralFan is offline   Reply With Quote
Old 06-23-2007, 05:17 PM   #2
Jim Krause
Uploads: 0
Default
Sounds like you have a good idea already. I've never had that problem after getting everything glued down but with my bad eyesight it has happened while joining sectional HO track.
Jim Krause is offline   Reply With Quote
Old 06-23-2007, 07:54 PM   #3
farish
Inactive Member
Uploads: 0
Default
Spray water to loosen the track from the glue. Remove the track section. Fix the problem and then relay the track. Under-cut a couple of ties on each end of the replacement track so you can slide the metal track joiner into place.
farish is offline   Reply With Quote
Old 06-24-2007, 11:57 AM   #4
fieromike
Uploads: 0
Default
You could use a method similar to that used to replace a bad turnout.
On the rail end that is raised, cut the spikes off of 2 or 3 ties so that you can slide the rail joiner back far enough that the matching rail will drop enough to slide the joiner forward and do its job. You may have to rewet the glue to allow everything to level back out.
Mike
fieromike is offline   Reply With Quote
Old 06-24-2007, 04:49 PM   #5
davidstrains
davidstrains's Avatar
Uploads: 0
Default
What you might want to put in your track laying procedure in the future is that after you lay each track section that is joined by a rail joiner, run your finger over the joint. That way you will identify and be able to correct the joint before you have applied the glue. It takes a little time initially but it saves a lot of correcting later. I also run a box car over each section as I go to test the joint and the gauge of the track at the joiner. At times - especially on curves you will see the track decrease in gauge ever so slightly, but enough to derail a 6 wheel truck on a loco or passenger car.
__________________
David in Virginia
davidstrains is offline   Reply With Quote
Old 06-24-2007, 10:01 PM   #6
Denyons
Denyons's Avatar
Uploads: 0
Default Rail Joiner
easist way to fix this problem is to slide the rail joiner out completely then solder the outside of the joint of the two rails making sure that the rails are level while you do the soldering. (A one minute job).
Denyons is offline   Reply With Quote
Old 06-25-2007, 10:52 AM   #7
PennCentralFan
Uploads: 0
Default
Thanks for the advice. What I did was to take a putty knife and slide it underneath the track and break the glue bond. I didn't use a lot of glue so it was pretty easy. I then lifted up the track enough to slide it out and back in the rail joiner.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tips for smoothing sectional track.. JasonRP N / Z Scale Model Trains 6 11-05-2005 05:34 PM
Small layouts, sectional track and CAD trackplanning hminky Track Planning 0 02-11-2005 09:24 PM
Brass Sectional Track? TrainClown FAQs 5 03-29-2004 01:53 PM
Peco C80 turnouts with sectional track? Jim Cullen N / Z Scale Model Trains 0 01-18-2004 12:34 PM
HO sectional track wskinn FAQs 4 05-17-2003 09:31 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright © 2006 - 2012 Zealot Forums | About Zealot Forums | Advertisers | Investors | Legal | A member of the Crowdgather Forum Community
