HobbiesHobby ForumWikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Tips, Tutorials & Tools
WON'T YOU JOIN US?
You are not a registered member and
are viewing this site as a guest.
Registration is simple and FREE.
Join this CrowdGather community today.
Registration offers the following perks:
» Less advertising throughout
» Post and participate in discussions
» Network with other forum members
» Free private messaging
join
Reply
Thread Tools Display Modes
Old 04-28-2004, 12:55 PM   #1
lgl007
Uploads: 0
Default First Model... need help!
I have been plastic modeling for over 15 years. Recently I ran into an internet article about paper models. So I decided to try one. I bought the 1:33 Halinski P-51D Mustang that has a medium difficulty rating. I have some questions that I hope you all can help me with...
1) Wow… this is NOT an easy project… are all the instructions in these kits so difficult? Or are there kits that have better picture instructions? (GPM perhaps?)
2) Many of the paper cut outs have to be glued to 0,5 or 1,0 or 1,5 mm cardboard/paper… where do I get this? I mean paper is not sold in mm thicknesses in Canada? What do you use? Is there a conversion chart from mm to lbs maybe?
3) There are a number of TEMPLATES at the bottom of page 1 or 2 (can’t remember now I’m at work and apparently these are to be made of “wire” and specified by 0,3 or 0,8 etc… does this mean 0,3mm or 0,8mm? Is there a conversion chart from mm to gauge maybe or is “wire” sold by mm thicknesses? Oh, and where do you get it?
4) The canopy is to be made of “FOIL” what does this mean… just clear paper?
5) The canopy, which is to be made of “FOIL” is in 8 pieces… how the heck do you glue them together so that they look like one piece? Does the UHU glue dry clear? Do I just glue the sides together?
6) It also states that some pieces, after gluing, are to be “polished” I assume this means “filed down”… so when you make the wheels it has 1,5mm, 2x 1,0mm, and 2x 0,5mm cardboard/paper pieces stuck together… then to get the nice rounded edges of the tires they say to “polish” them or “file them down”… what do you use to file down paper with? A nail file? Sandpaper, if so what kind?
Thank you all in advance for your help...
-Greg, Toronto
lgl007 is offline   Reply With Quote
Old 04-28-2004, 01:05 PM   #2
barry
barry's Avatar
Uploads: 0
Default
Hi
suggest you download one of NOBI's aircraft he has a couple for freebies these come with instructions in English.
Then search this site for "Ron" in the list will be several forums that show how to do most everything.
Barry
barry is offline   Reply With Quote
Old 04-28-2004, 01:38 PM   #3
cardfan
cardfan's Avatar
Uploads: 0
Default
Hi Greg,
Welcome to the group. Not all models come with complicated instructions. Some have very scant instructions . Like Barry said, I would also suggest that you download and build some simpler models. There are tons out there and it really helps to get simple techniques down and get the feel of paper types.
I use poster board and laminate that to make up the 1mm thickness on some parts. There are other methods discussed here. Great reason to dig through the archives.
I used a clear "frisket" type material for the 1 canopy I put together and used CA glue and the paper frame to bring the whole together.
I'm still working on the wheels thing myself...
Hope this helps with some of your questions and don't get frustrated.
Glen
cardfan is offline   Reply With Quote
Old 04-28-2004, 02:21 PM   #4
jleslie48
Uploads: 0
Default
I like to think of scant instructions as a puzzle to be figured out.
jleslie48 is offline   Reply With Quote
Old 04-28-2004, 02:25 PM   #5
lgl007
Uploads: 0
Default
jleslie48,
Well you are braver then I am... I just don't want to spend a month working on the skeleton to have to make severe changes for the skin to fit right...
Don't get me wrong, I will love the challenge, but for the last 15 years of plastic model making I've only worked on the very best kind... like Tamiya, Hasegawa some odd Eurpean Revell and such... kits that were/are for the most part perfectly designed... I'm pretty much of a perfectionist... hence my questions...
-Greg
Old 04-28-2004, 03:41 PM   #6
jleslie48
Uploads: 0
Default
I was too, in the beginning, then I realized with paper, if I didn't like it, I'd re-design, re-size, re-print, re-color,... at will.
Old 04-28-2004, 04:09 PM   #7
damraska
Uploads: 0
Default Re: First Model... need help!
Fly Model, GPM, and Halinski kits rate about the same for construction diagrams. Polish paper model kits are very much like puzzles. Recently, Halinski started using computer generated graphics (as in the P-51D), which represents both a step forward and a step back. The new construction diagrams generally show individual subassemblies in better detail than ever before, but they often do not reveal how said subassemblies attach to one another.
You might try a kit from Model Art at http://www.card-models.com. The Model Art kits I own (1:32: Bf 109, P-39, P-40, OV-10) include good instructions (and in English) by card model standards. Artwork generally falls somewhere between GPM/Halinski and older Fly Model Kits. The models come in .pdf format, so you can reprint yourself out of any mistake. I would recommend the 1:33 Bf 109. It features very nice artwork and good instructions though cockpit detail lacks.
If you can, make a backup of the model before you start. That way, if something goes wrong, you can try again. Unfortunately, the metallic printing of the P-51D precludes this. Study the construction diagrams carefully and start with whatever subassembly makes sense. Build it, put it aside, do another, and repeat. As the remaining part count goes down, I guarantee the overall model will make more sense.
This refers to the physical thickness of the cardboard. You can easily measure this with a decent ruler. You can create any thickness of cardboard by laminating cardstock to cardboard or cardboard to cardboard. Acid free spray adhesive works best for this.
Yes, 0.3mm and 0.8mm. I do not know the gauge conversion, but someone will. A good plastic model or train hobby shop will sell wire in various thicknesses and lengths for scratch building. Use hard wire! Soft wire, such as that used for flower arrangements, will quickly bend if subjected to any load. For my own models I use whatever wire thickness gets me in the ballpark--I do not worry about an exact match.
Clear plastic. Clear plastic printer sheets for making overhead projections work great. I prefer the ones for laser printers.
In the case of complex curved surfaces, such as the bubble canopy on your P-51D, you can't. If you want a smooth, flawless canopy, you have to vacuform it yourself (using a carefully constructed form made from the template you describe) or buy it. Fortunately for both of us, Gomix makes preformed canopies for just about every Polish card model on the market. In North America, you can get them at http://www.cardmodelers.org/.
Select the link entitled, "Gomix accessories for card models."
I use a big foam nail file to make wheels. Some people put a screw through the center of a wheel, stick it in a rotary tool, and sand it. Start course, end fine. If you dislike making wheels as much as I do, Gomix makes a wide selection of wooden wheels for Polish card models. (The Gomix wheels I ordered for my own P-51s were too thin. Chop them in half and add some cardboard in the center to get the right thickness.)
Good Luck.
Doug
damraska is offline   Reply With Quote
Old 04-28-2004, 04:22 PM   #8
lgl007
Uploads: 0
Default Thanks Doug...
Thank you very much for the answers Doug... that's exactly what I wanted to know...
Cheers mate...
-Greg
Old 04-28-2004, 06:42 PM   #9
Darwin
Darwin's Avatar
Uploads: 0
Default
Just a couple of quick comments to add to Doug's. You will reach a 0.5 mm thickness by laminating two pieces of 110 lb card stock. You will get 1 mm by laminating 90 lb card stock to "poster board" as available in the stationery sections of about any major supermarket these days. 1.5 or 2 mm is about equal to the thickness of matting material as found in any picture framing shop, or two thicknesses of posterboard. If on a really tight budget, the cardboard used for cerial boxes or soda pop 12-packs and 24-packs is about 1 mm. I've noticed that carton-type cardboard tend to preferentially curl in one direction when drying after laminating the part sheet to it. To help combat that, put the laminated sheets in a "press" while drying(like between two heavy books, ala preparing botanical specimens for mounting in a scrapbook). If laminating more than one layer of cardboard, alternate the orientation of the cardboard from one layer to the next (i.e., for cerial box cardboard, place printed side against printed side, unprinted side against unprinted side. Also be aware that cardboard and especially paper have a grain, the direction of which can be found by tearing it. Tears "with the grain" will be fairly straight and even. Tears "across the grain" will be curved and ragged. The grain is what usually causes bowing of the part when drying. When laminating, determine direction of the grain and orient the layers so that the grain direction alternates (vertical/horizontal) from one layer to the next.
I agree that you jumped directly into the deep end with your first model choice. I would recommend downloading some of the freebies from FiddlersGreen.net and building them, then try one or two of Kancho's or Merek's 1:50 scale kits (available from Teuton.org/dbarnett), or a couple of the PModel kits (available as electronic downloads from Spishop...look in the links section of this site). Paper models can be a rough transition coming from plastic media...much easier transition coming from stick-and-tissue background.
__________________
Zathrus stay....Zathrus die. Zathrus leave....Zathrus also die. Either way, bad for Zathrus.
Darwin is offline   Reply With Quote
Old 04-29-2004, 01:00 AM   #10
bwallaw
bwallaw's Avatar
Uploads: 0
Default
Greg
Here's a guage/mm conversion calculator for solid and stranded wire.
http://www.mogami-wire.co.jp/e/cad/wire-gauge.html
I like to swim in the deep water too. But the simpler models are definitely great skill builders.
B
__________________
\/\/-\|_|_/-\/\/
Bill Luk
In work: A growing collection of models
bwallaw is offline   Reply With Quote
Old 04-29-2004, 09:52 AM   #11
lgl007
Uploads: 0
Default
Thanks so much for your replies... you have all been extremely helpful. I hear you all about doing an easier model first but I'm not going to even try it. Things that don't look "perfect" to me are not worth doing... I just can't keep myself interested in non-detailed models... I have no idea why. Yes the P-51D is a bit tough but it's certainly not extremely difficult. I have received the English instructions from the wonderful people at www.halinski.com so that will help quite a bit.
I have now had a chance to study the plans for few hours and I am getting more and more confident about the project. I think the key is ... one step at a time... I was getting way ahead of myself trying to get my brain to work through the entire project... that's a no no in my book with this project... I think it'll be best for me to do one step at a time.
Thanks again guys... I'll keep you posted on the progress.
-Greg
Old 04-30-2004, 01:49 AM   #12
Darth_Nerdious
Inactive Member
Uploads: 0
Default
I also became interested recently in paper models. I was impressed with some paper aircraft I've seen, but they scare me a lot, much in the same way those paper gothic cathedrals do...
My first project will be this castle model, the very one which sparked my interest! I saw this one last year when attending a plastimodelism convention! It's simple and look good.
http://www006.upp.so-net.ne.jp/zen/P..._Download.html
If you haven't found the following link yet, maybe you'll want to take a look:
http://www.saturn.dti.ne.jp/~eastern/pcraft/index.html
They're far from perfect but I think they will look good on my desk, and if the maid destroy something when cleaning it won't be a tragic loss!
Darth
Darth_Nerdious is offline   Reply With Quote
Old 04-30-2004, 04:16 AM   #13
tino
Uploads: 0
Default
Hi lgl007,
I have p 51 D from halinski and halinski is the best and the hardest to build.
Can send me by mail the english instructions.
Regards
Diamantino
tino is offline   Reply With Quote
Old 04-30-2004, 09:18 AM   #14
lgl007
Uploads: 0
Default
Darth_Nerdious: Yes, quite a nice paper model of an ancient Japanese Castle... very nice indeed...
Tino: I don't understand... you would like a copy of the English instructions? If so, just give me your e-mail address and I'll e-mail them to you. Halinski sent them to be in .pdf format via the net.
-Greg
Old 05-01-2004, 03:35 AM   #15
tino
Uploads: 0
Default
lgl007,
My e-mail is diamantinoh@clix.pt or just clic on the bottom of my message were says email.
I send some private messages for you, sorry the mess.
Regards,
Tino
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
is the Model Card Spooky AC-47 gunship model any good? andrew ferguson Aircraft & Aviation 4 11-20-2005 12:58 PM
Space Shuttle model by Hobby Model: good or not? billmcc Space & Aeronautics 6 07-27-2004 02:01 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright © 2006 - 2012 Zealot Forums | About Zealot Forums | Advertisers | Investors | Legal | A member of the Crowdgather Forum Community
