HobbiesHobby ForumWikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Trains & Railroads > Model Railroading > HO Scale Model Trains
WON'T YOU JOIN US?
You are not a registered member and
are viewing this site as a guest.
Registration is simple and FREE.
Join this CrowdGather community today.
Registration offers the following perks:
» Less advertising throughout
» Post and participate in discussions
» Network with other forum members
» Free private messaging
join
Reply
Thread Tools Display Modes
Old 01-01-2007, 09:56 PM   #1
JoelP2600
Inactive Member
Uploads: 0
Default Dusty Track/Clean Track, Christmas Village
Guys,
It's been a very long time since I had and HO Scale model train, but I seem to remember having to sand or clean the tracks now and then, otherwise the train would loose contact with the track and stop moving.
My wife and I are setting up a Christmas village, which will probably be up year round, we are planning a train which goes though a tunnel and passes though the village. The issue is that most likely the tunnel will be rather long and difficult to clean without taking the village apart.
If the track is covered (by the tunnel) should I have issues with stopping trains?
Also, I remember a kind of "Flex" track, it was brass I think and could be bent, would it maybe not corode as bad and/or stay cleaner longer??
Any suggestions would be great.
JoelP2600 is offline   Reply With Quote
Old 01-01-2007, 10:01 PM   #2
LongIslandTom
Inactive Member
Uploads: 0
Default
Hello and welcome,
Brass is the stuff that tarnishes fast and loses electrical conductivity. That's what you want to avoid.
What you want to get is Nickel Silver track. Even when tarnished, nickel silver still retains conductivity, so it needs cleaning less.
If you are setting up just a circle of track, just get a set of Kato Unitrack. It's nickel silver, and it's easy to assemble and disassemble. Flex track is intended for permanent layouts, and it needs to be fixed down to keep its curvature.
Hope this helps!
LongIslandTom is offline   Reply With Quote
Old 01-01-2007, 10:43 PM   #3
shaygetz
shaygetz's Avatar
Uploads: 0
Default
Welcome to The Gauge, Joel
Here's a link to a thread I did on how I keep my track, both Christmas and regular layout, clean. >>> http://www.the-gauge.com/showthread.php?t=23668 Hope that helps
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
"He's a Christian, Jim, but he's unlike any we've ever seen before..."
My website>>>
My blog>>>
shaygetz is offline   Reply With Quote
Old 01-01-2007, 11:22 PM   #4
Jim Krause
Uploads: 0
Default
For the tunnel, you can purchase several varieties of track cleaning car or make one yourself. Pick an inexpensive box car and find a piece of scrap Masonite. Cut a piece of Masonite wide enough to cover both rails but not wider than the car body and about 2 inches long. Put two holes on the centerline of the piece about 1 and 1/2 inches apart. Epoxy 2 two inch nails in the holes in the Masonite. Drill matching holes in the underframe of the car, between the trucks The holes should be slightly larger than the nails. Put the two nails in the holes and set the car on the track. Hook up your loco and pull the car around the layout several times. You will have clean track.
Jim Krause is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to clean old track pinkerton HO Scale Model Trains 2 02-28-2007 09:46 PM
Clean wheels and track Nomad DCC & Electronics 3 02-27-2007 01:36 PM
Clean That Track !!!! colin DCC & Electronics 7 01-27-2006 03:19 AM
Lionel Village Trolley - Track Type? Conductor Zorak G / O / S Scale Model Trains 8 12-30-2005 09:44 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright © 2006 - 2012 Zealot Forums | About Zealot Forums | Advertisers | Investors | Legal | A member of the Crowdgather Forum Community
