» Less advertising throughout
» Post and participate in discussions
» Network with other forum members
» Free private messaging
Thread Tools | Display Modes |
#1 |
Inactive Member
Uploads: 0
Had anyone heard iof this product?
And if so, do you have any information on how it's used and if it looks good? I saw a little clip in the lastest MR and was kind of curious... Thanks alot!! |
#2 |
Now I'm AMP'd
Uploads: 0
Years ago I saw it at a LHS. Never tried the stuff though.
Maybe some one here has.
__________________
(Ed)itor Gauge E-Mag NARA member #78 I went to my HAPPY PLACE, but it was closed for renovations...... Gauge E-Mag: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#3 |
Inactive Member
Uploads: 0
I think I have used every possible product, technic, suggestion, idea, or combination to model mountains and terrain. On my latest layout I am using a one, two, three procedure that works great. Bacic form is Great Stuff, which is then covered with plaster cloth and finally painted with Flex paste. I prefer Poly Terrain but they have vanished??? Cheaper, better stuff. Thankfully Hobby Lobby had Flex Paste at 50% off after Christmas and I stocked up. While you can't cast Great Stuff, you can control the final result by how yo add the plaster cloth. You end up with a very light weight terrain that takes whatever scenery you desire to apply.
Doc |
#4 |
Uploads: 0
No worries about the flammability of Great Stuff?
I can see it as a quick, cheap way to make mountains, but the wall my layout is going on backs the furnace cubby, and I don't want to add a potential SEVERE fire hazard (wood, paper, scenery, etc., will be bad enough). ![]() |
#5 |
It's not rocket surgery
Uploads: 0
Dragon,
If you have all the proper (manufacturer recommended and building code) clearances around the furnace, you should not have a problem. I imagine the majority of the flammable hazard comes from the isobutane that is used to spray the product. At the DOW website, it is interesting to note that the foam is certified for "fire migration prevention" (helps to slow the spread of fire), yet the MSDS states that toxic flammable gasses are produced under "decomposition conditions" including elevated temperatures! More info: http://greatstuff.dow.com/greatstuff/pro/fireblock.htm http://www.dow.com/PublishedLiteratu...romPage=GetDoc All in all though, probably no more dangerous than other building materials in your home. Andrew
__________________
Check out The Gauge's To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Questions? Visit To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. at The Gauge for all kinds of How-To's Planning a layout? Try the To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. form |
#6 |
Uploads: 0
I used MinM years ago. It's a two part expandable foam, which probably came from the floatation , or "insta-pak" industry. It seems to be the same stuff.
It's decent for lightweight rock castings for modules, but for a home layout I'd use foam sheets and plaster rocks. I just like the way plaster reproduces details and takes stains. I ran across this guy at the big RR show last month who makes rubber rocks. www.cripplebush.net Honestly, this is some of the best rock work I have ever seen. Neat concept, they're flexible, lightweight and easy to cut, but they are expensive. I really wanted to buy one of them because the strata was perfect for a short cut that is on my layout. However, I just bought a Tsunami and associated stuff and had reached my daily spending limit, so I passed.
__________________
Russ To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#7 |
Uploads: 0
hey zedob - those are the best rocks I have ever seen. That may even include real ones!
nice to see someone being creative with their geology degree! kevin |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Spare 6.5 minutes of your time? | EngineerKyle | Photos & Videos | 15 | 12-24-2006 11:11 AM |
| My 15 Minutes......... | N Gauger | Getting Started | 35 | 07-07-2005 01:26 PM |
