» Less advertising throughout
» Post and participate in discussions
» Network with other forum members
» Free private messaging
Thread Tools | Display Modes |
#1 |
Uploads: 0
OK...I haven't done one of these for awhile...but after poking around here at The Gauge for the last couple of weeks, I've gotten inspired to try a little kitbash...
I thought I'd see what I could come up with for this little cheapo kit I picked up at a swap-meet last summer... Here's the kit... ![]() I assembled the outer walls, but replaced the rear wall, & second-story floor with some scribed styrene siding... ![]() I went ahead, & added the upper portion, & cut the original rear wall in two pieces, to make an annex at one end... ![]() Well, that's where she stands at this point...I'm going to try & scratch something up to use as a roof...more on that later! ![]()
__________________
-Drew- NARA Member #48 Life is all the stuff that happened while you were makin' other plans. |
#2 |
Inactive Member
Uploads: 0
Looking forward to your progress Drew, so far it's looking great!
#3 |
Out AZ way
Uploads: 0
I have one of those in N scale that I haven't built yet. I'll be following your progress with great interest. Looks like you have a great start...
__________________
Don (EZ) Day Railroad tycoon NARA #88 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#4 |
Uploads: 0
I have already put mine together and never thought of using a wall like you have for another building. I ended bashing a store house to go with mine... live and learn...great job of it you are making, look forward to your next post with an update......steve
__________________
NARA Member #109 A wise man, is someone who sees everything, says little, and does what he can.. Steve... To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Ausien |
#5 |
Uploads: 0
Thanks for the comments guys!
![]() Last night I managed to get some cardstock cut for the roof...I'm goinfg to try & cover that with some corrugated roofing... ![]() Steve, I'm planning on adding some type of storage shed to mine, also...maybe an open-air shed for lumber...?
__________________
#6 |
Uploads: 0
I painted the roof black, & I'm in the process of adding some corrugated roofing that I made from alum. foil...
I also added some posts that I found in the scrap box...They didn't quite look right at the ends, so I compensated by taking some of those plastic lumber loads from the kit, & using them to fashion some makeshift walls... ![]()
__________________
#7 |
Gauge Oldtimer
Uploads: 0
Looking Good Drew.
__________________
NS Cyclopedia http://nscyclopedia.weebly.com/ Owners Matthew Miller and Todd Harbaugh |
#8 |
Uploads: 0
Thanks Matthew!
Happy Thanksgiving, everyone! Well, I've gotten some painting done on the structure... To tone down all those cheery greens & yellows, I spray-painted the entire structure flat black... ![]() Then I switched to Polly Scale acrylics...I brushed on a wash of Rail Tie Brown, then dry-brushed with Dirt, Mud, & Aged White...I was trying to get the look of weathered wood... ![]() Now I need to add some weathering to the roof... I'm hoping to get some more done today... Film at 11! ![]()
__________________
#9 |
Uploads: 0
like the paint job
__________________
jim |
#10 |
Uploads: 0
Thanks, Jim!
![]() I got the roof finished today... ![]() I was a little worried, because gluing the corrugated foil to the cardstock roof caused it to warp slightly...but in the end, it gave the roof kind of a saggy look that I thought was kinda nice... Now I've got some detailing work to do...
__________________
#11 |
Out AZ way
Uploads: 0
Yeah, I agree, the roof looks great that way, naturally aged that's for sure...
Don't you kinda wonder, with all the wood, roofing and paint they store in there, why don't they use a little bit of it to fix the place up? ![]() ![]() ![]() ![]() Can't wait to see the next step. ![]()
__________________
#12 | |
Uploads: 0
Quote:
I agree, sometimes we tend to overdo the ageing & weathering. It certainly is impressive & requires a lot of talent to produce some of the effects we manage. Perhaps it is , as my friend Lynn Austin says, we don't always know how to model "time" . George Selios is an example of out of whack "time" modeling--- He does fantistic work, however the F&SM is set in the Depression years. Almost everything on the RR is run down, dilapidated, & in general in poor repair. That would be fine, IF the layout was set a few years LATER. While we are used to seeing structures that survived those years that are all run down, etc, one needs to remember that untill the depression hit things would have been much better maintained, & MANY years newer than we see them now. When everything went to pot the ability ( money) to keep things up dwindled & things were let go , but it would take a number or passing years to really show up.
__________________
L V Dave Instant Glue ??? ---SOLDER -- Now THATS INSTANT!! |
#13 | |
Uploads: 0
Nice work Drew. I like both your re-design and the weathering.
Quote:
Wayne |
#14 | |
Uploads: 0
Quote:
I watched a video of him building a brick building once, I could not Believe how FAST he is , of course he has to be to have done all he has on the F&SM in only one lifetime, and to think he has time left over to put out a FSM kit each year. Parhaps he intended it to be a caricature,but do you know anybody brave enough to ask him that?? ![]()
__________________
#15 | |
Uploads: 0
Quote:
![]() Wayne |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Kitbasher's Diary - Glasgow Jct Depot (N Scale) | Drew1125 | The Academy | 28 | 07-11-2005 09:41 AM |
| Kitbasher's Diary - N Scale Water Tank | Drew1125 | The Academy | 10 | 04-23-2004 07:44 AM |
| Kitbasher's Diary: A Depot For Glasgow Jct (N Scale) | Drew1125 | Scratchin' & Bashin' | 15 | 03-21-2004 06:51 PM |
| Kitbasher's Diary - Model Power Freight Gepot (N Scale) | Drew1125 | Scratchin' & Bashin' | 57 | 01-24-2004 01:52 PM |
| Kitbasher's Diary: Bachman Rural Freight Statoion (N Scale) | Drew1125 | Scratchin' & Bashin' | 45 | 12-02-2003 03:17 PM |
