HobbiesHobby ForumWikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Trains & Railroads > Tips, Tutorials & Technical > Technical > DCC & Electronics
WON'T YOU JOIN US?
You are not a registered member and
are viewing this site as a guest.
Registration is simple and FREE.
Join this CrowdGather community today.
Registration offers the following perks:
» Less advertising throughout
» Post and participate in discussions
» Network with other forum members
» Free private messaging
join
Reply
Thread Tools Display Modes
Old 09-30-2004, 02:20 AM   #1
trainsteve2435
trainsteve2435's Avatar
Uploads: 0
Default queston about wireing....
hello everyone, i have a queston about wireing my layout for DCC. im useing a NCE PHP with a 10 amp booster. im going to run my two bus lines for track power, but im wondering what do i need to add in order to add switch machines and signal blocks? i know there is more wireing involved, but im not sure what type. any information is appreciated. thanks!
__________________
Steve
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
trainsteve2435 is offline   Reply With Quote
Old 09-30-2004, 10:05 AM   #2
SteamerFan
Uploads: 0
Default
Well steave, that's a complicated loaded question.
Basically for Signal blocks, run one rail contious feed (common rail, no gaps) and gap the other rail on for your blocks and using a Block Detector for each block you can build your signal system. it can get more complicated if you want to go 2 blocks out detection, you'll have to do more fancy wiring.
as for switches, if the frogs are insulated, you won';t have to do any fancy wiring for them. if you want to have them DCC controled, you'll just need an Accessory Decoder and a dcc ready (most are) switch machine.
__________________
Jay
Quote:
A collision has its good points as well as its bad ones -- it indicates there is something moving on the railroad. John F. Stevens - 1905
SteamerFan is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A Simple How To Book Explaining DCC Wireing? planeshavings42 DCC & Electronics 6 11-01-2006 10:41 PM
bus wireing emt49 DCC & Electronics 3 06-14-2005 06:26 PM
wireing question for all you veterans.... trainsteve2435 DCC & Electronics 2 02-07-2005 06:44 PM
Queston? Goattee Scratchin' & Bashin' 7 02-16-2004 09:14 AM
wireing servo pack for easy charge rc10gt3jimbo RC General & Getting Started 5 12-14-2003 03:55 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright © 2006 - 2012 Zealot Forums | About Zealot Forums | Advertisers | Investors | Legal | A member of the Crowdgather Forum Community
