» Less advertising throughout
» Post and participate in discussions
» Network with other forum members
» Free private messaging
Thread Tools | Display Modes |
#1 |
Uploads: 0
Well, I started this thread before, but apparently, it got lost in the crash...
This shows the process I've been going through to come up with a station for the town on my N scale layout... It all started with this kit roof I found in the scrap box...I used it as a starting point, & built some walls to fit it out of Evergreen siding...(the bay window came from a DPM kit)
__________________
-Drew- NARA Member #48 Life is all the stuff that happened while you were makin' other plans. |
#2 |
Uploads: 0
I found this piece in a Walthers HO meat packing plant...
__________________
#3 |
Uploads: 0
I used it to make a freight shed addition to the station...
__________________
#4 |
Uploads: 0
I added another little addition, & added some doors & windows from the scrap box...
__________________
#5 |
Uploads: 0
I decided I didn't want to use the kit roof I started with, so I made a roof from plain styrene...I also found another piece of styrene to use as a base/platform...
__________________
#6 |
Uploads: 0
I decided I wanted the platform to look like wood, so I scored it with a razor saw...
__________________
#7 |
Uploads: 0
I primed it flat black, & dry brushed it various shades of brown to give it more of a "wooden" look...
__________________
#8 |
Uploads: 0
I had ended up with a window opening, & a notch in the top of the shed wall that I didn't want...
__________________
#9 |
Uploads: 0
My solution was to make a chimney from strips of styrene covered with H&R brick sheet...
__________________
#10 |
Uploads: 0
Here's the chimney in place, with a crown & pipe made from styrene...
__________________
#11 |
Uploads: 0
Here's a trackside view...I've added a roof to the freight shed, & a covered loading platform...I also added a freight door to the shed, & I found this little dome thingy in the scrap box, & cut a piece off to serve as a roof over the bay...
__________________
#12 |
Uploads: 0
Thanks for all the nice comments, guys!
I've gotten a little more done... I painted the styrene roof flat black, & then glued strips of tissue paper to it to look like roll roofing, or tarpaper...
__________________
#13 |
Uploads: 0
I painted & weathered the roof, added some "glass" & shades to the windows...here's a view of the interchange side of the depot...
__________________
#14 |
Uploads: 0
Here's the other side...I'm going to try & raise the platform & structure slightly, & then build some type of foundation under that lopsided shed addition...
__________________
#15 |
Uploads: 0
Thanks for the nice words, guys!
![]() I've gotten a tiny bit more done on this one... I put a piece of mat-board under the structure to give it a little elevation...this always helps in N scale, to make the structure a little taller, & lowering the profile of the adjacent track(s)...
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Kitbasher's Diary - Model Power Lumber Mill (HO Scale) | Drew1125 | Scratchin' & Bashin' | 16 | 06-25-2007 07:37 PM |
| Kitbasher's Diary - N Scale Water Tank | Drew1125 | The Academy | 10 | 04-23-2004 07:44 AM |
| Kitbasher's Diary: A Depot For Glasgow Jct (N Scale) | Drew1125 | Scratchin' & Bashin' | 15 | 03-21-2004 06:51 PM |
| Kitbasher's Diary - Model Power Freight Gepot (N Scale) | Drew1125 | Scratchin' & Bashin' | 57 | 01-24-2004 01:52 PM |
| Kitbasher's Diary: Bachman Rural Freight Statoion (N Scale) | Drew1125 | Scratchin' & Bashin' | 45 | 12-02-2003 03:17 PM |
